Tempering Question
rlowery
Active Member
I was tempering 4 D2 blades today 450 degrees for 2 hrs. I got tied up on business and let it run over the 2 hrs. When I got back the oven had cooled down to 375 degrees. I am not sure what to do, any help would be greatly appreciated. Start heat treat over, retemper or what????
Thanks in advance.
Rickey
Did you set the oven to only run for 2 hours? If that's the case and it was just in the cool down faze you're ok. If the oven just shut down, put them in for another cycle the blades will be fine.
Thanks Ty it shut down after 2hrs,, I appreciate the quick reply
