trashemann
Member
I have been thinking about making a tanto blade but unsure on the grind process as whether or not to grind the tip first then the flat or vice-versa. Would appreciate any info.
I just ground this about an hour ago, Arkansas style Tanto! I've never done it before either, this is just off a 36 grit belt, freehand. I ground the bottom bevel first, then the top clipped bevel and lastly the end bevel. 3/16" thick, 15" long. Of course, this is single bevel on one side only too. Wasn't really that hard at all, just try it.
