cardoso5fr
A 5/8 (almost)
15,7 cm long closed, 2,5 cm high closed, 1,1 cm thick to the pivot, 24 cm long, 7,9 cm sharp.
100MnCrW4 blade, 5,9mm thick, Full oil hardened , gold flash tempered. 1/3 hollow grind.
Spacer and handle in T40 (grade2), 1,2 mm thick for each scale. Pinned and epoxied spacer
Chasse et spacer en T40 (titane grade 2) de 1,2mm d'épaisseur. Spacer collé et riveté avec laiton.
I began that morning to 8h30, it was heat treat at 11h50. I re started at 13h40, finished the razor at 16h40. I completed the sharpening at 18h tonight
I have had a good work today
