N.N
Small neck/boot knife from a file. 2 1/4 in modified warncliff cutting edge, about 5 in overall, black micarta scales, blue spacers, 3/16 lanyard hole, highlighted with a wire rap sanded smooth.
I don't know if the wire rap was a good idea and I can't decide if I like it. What do you think?
I know it's something I should worry about, but will it really effect the usability? I think there is a VERY small warp in the steel that I didn't get corrected just perfectly....At the very corner tip on the right side top, the spacer/micarta has seperated from the steel. It's so small I don't know If I can fix it. But you can see light through it if you hold it up to a light. I might try a syringe and some epoxy just to fill the paper thin gap. Any other suggestions?
![2013-10-18_08-19-12_239.jpg 2013-10-18_08-19-12_239.jpg](https://knifedogs.com/data/attachments/28/28042-3f1212888527aa89181877a13a235d17.jpg)
![2013-10-18_08-19-45_543.jpg 2013-10-18_08-19-45_543.jpg](https://knifedogs.com/data/attachments/28/28043-9e5c9ac36bde7d3d6382d0c9e5b4a30e.jpg)
![2013-10-18_08-20-12_104.jpg 2013-10-18_08-20-12_104.jpg](https://knifedogs.com/data/attachments/28/28044-25fa307b204e44125b22081dedff598f.jpg)
![2013-10-18_08-20-35_629.jpg 2013-10-18_08-20-35_629.jpg](https://knifedogs.com/data/attachments/28/28045-8fc59a6d27ef61df25706d701ce09d8d.jpg)
![2013-10-18_08-22-20_300.jpg 2013-10-18_08-22-20_300.jpg](https://knifedogs.com/data/attachments/28/28046-b44ea99955ca0d390576da335f1a3898.jpg)
![2013-10-18_08-22-44_676.jpg 2013-10-18_08-22-44_676.jpg](https://knifedogs.com/data/attachments/28/28047-81143e441a52a4dff42b57ebad41adb9.jpg)
