Mark,
Handstiching- yes. Saddle stitch all the way.
If your you're gonna use that little info as a tutorial then it's worth mentioning that I do temper the entire clip. After hardening I sand it up enough to get it bright again so I can accurately see the colors then temper the straight areas to golden brownish and then spring temper the curved part. You could also temper the whole thing in the oven then draw the curve down to a spring temper after that. You definately need to temper the whole clip though to avoid the brittleness of un-tempered martinsite ESPECIALLY where the rivet hole is .
Rob,
These sheaths go back all the way to right after the hammer-in last Jan. LOL. I have been keeping plenty busy though. I've been claiming I was gonna build a forge for so long I was beginning to not even believe it myself, LOL. But the time has finally come and I've got the body done, burner and blower assembled and ready to begin wiring the PID and SSR control system.
I was about three cuss words from giving up on trying to weld things myself, admit defeat, and call ya to throw myself at your mercy. But I finally discovered I had too much draw on the circiut I had the welder on and swithing to another line fixed me right up.
I'll tell ya forges sure don't build themselves but I REALLY wanted to build my own And now I'm glad I persevered through a few obstacles.
Take care buddy, Josh
