C Craft
When designing a sheath for fixed blade I always kind of struggle with this decision. If I do a pouch type sheath I always start out with more leather up top of the sheath than I usually end up with. What I am trying to say is I almost have to see the knife in the formed sheath to determine if I have enough their to corral the knife and still not to high up to get a hold on the handle of the knife.
I have seen sheaths where there is only enough of the knife sticking out that you have to use two fingers to retract the knife, I like to have a little more to get a hold on! Yet I know if I leave too much of the handle sticking out the knife is not going to be easy to keep in the sheath! So I usually end up making the pouch type/ fitted sheath a little taller than needed and trimming back on the height till I feel it looks and feels right.
OK am I just weird or does anyone else struggle with this decision?
Next question on design. I don't do a lot of tooling because the period of time I like to build knives for it wouldn't have been appropriate. However we all got to eat and a buyer wanted a fitted sheath with tooling on it for another of my knives. My solution was to do the form fitting and then letting it dry quite a bit to make it hold the fit, before doing the tooling. However by the time I got thru and stitched the whole thing up I had lost some of the form fit. In other words what was a tight form fit seemed to relax out quite a bit, by the time I got thru tooling.
How do you achieve this, a form fitted sheath, with tooling on it?
I am going to throw one more out here. Fringe on a knife sheath I have tried this several ways. One of the first ways I attempted was while doing a Spanish braid stitch or some call it a Mexican braid stitch and weaving in a fringe with each stitch. It worked but was one humongous pain in the back side. The last one I did I layed out on one piece of leather each and every strand of the fring and cut the thing out attached to a shaped strip acting as a welt in the sheath and used a two needle saddle stitch to sew it all together. Anyway I have looked at it there is a lot of time evolved in making a sheath with fringe!
Is there an easier way?
Anyone want to share how they go about fringe on a sheath?
