I go to 220 pre heat treat on the sander, after heat treat I do the flats on the sander with a 220 grit then 320, and finish grind the bevel with a 120 to the finish thickness, then go to 220, then 320 till all 220 grit scrathes are gone. Then I start hand sanding with 220 grit and progress up to 2000 grit. I see no need to go any higher than 220 pre HT. because you will have to clean up the scale, plus most don't grind to the finished edge thickness pre HT, unless it is an air hardening steel wraped in foil for the HT.
Just the way I do it.
