Erin Burke
Hey guys... I'm building my first folder - a balisong w/ differentially heat-treated 1095 blade and pivot bushings - and I have a question on my heat treat/reaming sequence. In a nutshell, my question is this: should I do final reaming of my blade pivot holes (1/4") prior to HT or after. There are several subquestions that figure into this.
I'm positive that this info is out on the web somewhere, but I must be missing it. Thanks in advance. Erin
- Should I harden the tang of the blade (pivot holes)? My inclination is "yes", for a harder, more wear-resistant pivot.
- If I ream before HT, will the black crud screw up the precision of my pivot holes or can I simply clean it up afterward... maybe with a second reaming?
- If I ream after HT, I assume I'll have to buy a carbide reamer.
