springer82
I've made a few knives. Nothing fancy. I tried my hand at forge welding. As they say,,, If at first you don't succeed. My first try turned out,,, OK. I did not hammer the twists out far enough. I think??? OK,,, now I have to say SORRY. I'm not very good at this stuff. You will have to make the photos larger. I don't know how to do that. If you look at the blade side you will find a few black lines at the edge. I think that is from the twist. Not sure. Maybe I did not clean it good enough?? That was a test. Just stuff I had around the garage. It is made of 5160 & 15n20. The next one is what will be a good blade. Maybe. I hope. ;-) I ordered more steel. It will be made from 1080 & 15n20. My brother in-law wants a fillet knife. He does not know I am making it. My biggest concern is heat treating. They are "SO" thin. I am afraid it will turn out like a pretzel. If anyone can take a look at the photos and tell me what I did to get the lines in them I would really appreciate it. A little help with heat treating would be great too. Do you think a rose bud on my torch would be the best way to harden the edge or should I dip it??? Thank you in advance for your time.
