scott.livesey
Dealer - Purveyor
O2 or 1.2842 or 90MnCrV8 is a basic tool steel.
Basic composition resembles a hi manganese 1095. I just purchased a small quantity that was made by Simonds, the saw and file folks.
Composition:
Carbon: .85-.95
Silicon: .20-.35
Manganese: 1.3-1.4
Moly : .20-.30 (European version may contain Chrominum 0.25 and Vanadium 0.15)
Heat treat appears to be the "usual" for low alloy tool steel. Heat to 1425F. Soak for 5 minutes. Quench in warm oil, 125F. Temper at 350F for one hour. Cool. Temper at 350F for one hour. Result should be Rc62-64.
I haven't found anyone on this side of the pond who carries this steel.
On the Old World side(sounds better than right side) I have found the following references:
http://www.metalravne.com/selector/steels/merilo.html
http://jkz.cz/en/node/377
http://www.ozct.com.tr/en/pdf/1.2842 90MnCrV8.pdf
http://www.bestar-steel.com/site_files/files/material_data/BE2842.pdf
all of these references list "cutting blade with high dimensional stability" as a commercial use.
hope this is helpful.
Composition:
Carbon: .85-.95
Silicon: .20-.35
Manganese: 1.3-1.4
