M
Martin Swinkels
Guest
Hi guys..
I´m very new here to the forum, and I see alot of new names, so I´d like to introduce myself a bit here.
I mainly work with halftanned leather and kydex. I like halftanned because it has a core of rawhide, and therefore is very hard to cut or pierce. It also keeps it´s shape very well, and once treated wth sno seal it is extremely weatherproof.
I mostly use kydex liners which sometimes are removable for cleaning.
I like modular sheaths, with lots of carry options. I call them the Technical models, which easily could transform into tactical..´
The Classic sheaths have the kydex fixed inside. They all have drainage holes, and can easily be rinsed out under water.
My retentionstraps, when present, pivot around a rivet and can be attached in 2 different positions.
Enough talk.. time to show some sheatwork..
I recently finished these three..
They all have removable kydex liners, and a modular set-up. All pieces are detachable, and movable to suit as many particular carry needs as possible.
Kydex is 0.093”, and the leather is 2.5mm halftanned.
Kydex backplate is 0.125” kydex.
HG-55
This one takes a teklok, droploop or IWB loop.
SFNO LE
The kydex backplate and the pouch will take a large teklok. The back of the loops can be mounted with long molle loks.
NMSFNO
This one symetrical too. The eyelets in the loops take tekloks, large or small molle loks.
some other models:
I hope you like them.
HG-55
SFNO LE
NMSFNO
some other models:
