Perryknifeworks
- Triple-O Knife When you are truly Out Of Options this is the knife to reach for. Not many of us have the time to become knife-fighting experts and unless you really are an expert, you’ll fumble that folder when confronted with a deadly threat at knife range. That’s just what adreneline does. This knife was designed from scratch to be easily used in the kind of desperate situation that calls for a knife beaten, bruised, deprived of your sidearm, and unable to escape. Maximum effectiveness even with minimal training. For LEOs, private security, and anyone who has ever thought what if?
- A thick (4.5mm or .177″), flat-ground blade to power through anything.
- A tall, wedge-shaped guard to keep your hand off the cutting edge without impairing combat effectiveness.
- Finger grooves that guide your hand into position when milliseconds count
- An upward-oriented cutting edge–because the soft parts of your attacker (belly or throat) are best met with an upward thrusting motion using powerful muscles like the biceps and legs.
- Compact size: a 3-1/4″ blade in 6-5/8″ OAL, for easy carry on a belt, under the arm on a vest, or in a boot.
This is not a fancy “tactical folder” that looks cool being displayed in your collection. It’s a simple hunk of sharpened metal and molded plastic that can save your life when literally nothing else can. If you can’t dial 911 because you ARE 911–this knife is for you.
Comes with a sturdy Kydex sheath to keep it close at hand.
