heres what i do, i also write in the open spot on the bottom right side the knife specs. (length, steel, finish, handle, style, price, date, and buyers name)
knife care
This knife is hand forged from 5160 high carbon spring steel so you have to remember that it’s not stainless so it will rust if you don’t take care of it, if it gets wet (or bloody), dry it off really good (canned air works really good) before putting it back in the sheath (and make sure the sheath is bone dry too) you can rub some wax on it to help prevent rust, what I like to do and have found it to be the best of all the methods I have tried, rub the entire thing with mineral oil (make sure you get it into the all small corners real well) handle and all and then rub some wax over the entire thing, most any bowstring or furniture wax will work but I prefer straight bees wax. if it’s really humid or your using the knife a lot you should rub it with oil every week or so if the air is fairly dry once a month will do just fine. there are many types of oils that will work but mineral oil is the best of all that I have tried (wd40, olive oil, vegetable oil, motor oil, neatsfoot oil and honing oil) wd40 and motor oil work very good on the blade but aren’t good for the leather sheath and will mar and discolor the finish on the handle
sheath care
The sheath is made from high quality vegetable tanned leather and stitched with waxed nylon thread (35# breaking strength) and I neatsfoot oil every part before stitching it together and then again before I put it in the mail. All they require is a good oiling every once and awhile, I oil them every time they get wet (probably over kill) and every month or so when not being used, I prefer neatsfoot oil if the leather is really dry but normally I use skidmores leather cream, Montana pitch blend or mink oil is also very good and most other leather or saddle care products will work fine.
If you sell, trade, or give away this knife please give them this piece of paper or contact me and I’ll send you another. if you have any questions, suggestions, ideas or problems please contact me, I can be reached at:
Connor McCalmont
1443 Miles City Cutoff Ekalaka, Mt 59324
phone: (406)-775-****
email:
stu***@hughes.net
Connor McCalmont
Bladesmith
