Ron Bendele
On the 'IKBS Making Of' page at http://www.ikbsknifetech.com/11/1504.html they speak of using an optional washer.  Does anyone use a washer?  If you do, where do you get it and what size is it?
On another thread Les Voorhies says to use the following counterbores:
"1/8" pivots use 1/4" CB, 3/16" pivot uses 5/16" CB and 1/4" uses 3/8"."
Michael Burch added:
"I use 7/32 pivots ... and use an 11/32 counterbore."
I typically use the 7/32 pivot, but have used and have 1/8 and 3/16 as well. I assume the washers would need to be different for each.
