Dwane Oliver
I have been using the Wicked Edge sharpener , it works great.
BUT
And maybe I'm just being anal. The angles are not correct. If all blades were 1" deep , it would be close to what it says on the tool. On a 2" deep blade , 17deg is really about 14deg. The problem is that the adjustment is in the abrasive , not the blade.
I just wanted something better....So I made this.
Its adjustable from 0 deg to 50 deg. I made a tool to set it at 17 , 20 and 25 deg easily. It works great too. I need to order a leather belt now.
I run the belt backwards, so its pulling away from the edge , tracks great.
It bolts in the existing holes for the flat platten , and the platten is tilted back to its max.
I also made the holder for the blade. Its made from some .250" X 2" 1095. I HT'ed and tempered it back to spring hardness. Holds it tight and square.
Took just a few min to put this 20 deg edge on this knife. The first time is always a challenge. Took it up to 15 micron , thats the finest I have on hand , but it does shave arm hair at that.
BUT
