Hi Folks,
i just finished my HT oven build and have a couple of questions regarding the initial start up. I seem to recall reading something about gradually working up to max temp by setting the SV at a temp of 500(?)F, allowing the oven to go back to ambient temp, and increasing the temp to maybe 750f, allowing to return to ambient, and so on. As I recall, this was to accomplish 2 things.
1) This process is supposed to make the heating element last longer (I have no idea how, maybe an oxide layer??)
2) helps the PID with its "learning curve".
Does anyone have any input on any of this?
The second part of my problem has to do with programming the Auber Instruments Ramp / Soak PID. I've spent several evenings pouring thru the online manual for it, and can't seem to make any sense of it. It made my daughters electrical engineer boyfriend leave scratching his head after 2 1/2 hrs. He did get it to fire the element, but I'm no closer to using it at anything near its potential. Anyone have any suggestions on this PID you'd be willing to share?
Thanks in advance for any advice on either of these 2 issues!
