Chuck Gedraitis Knives
I was picking up some sandpaper and saw this stuff on the shelf. Withstands heat up to 2000deg. Spray it on let it dry. Then bake at various temperatures to cure it. It is silicone ceramic based. I thought that it might work on blades.
What do you think?
VHT FLAMEPROOF™ COATING
VHT FlameProof™ Coating will renew and extend the life of any surface exposed to extremely high temperatures. This unique coating is a matte finish, silicone ceramic base widely used by the automotive industry on exhaust systems and the aerospace industry for jet engines, re-entry vehicles and other high temperature applications. VHT FlameProof™ Coating will withstand temperatures up to 2000°F (1093°C) and is ideal for use on headers, exhaust systems, or wherever an extreme temperature coating is needed.
Temperature: 1300°F-2000°F (704°C-1093°C)
			What do you think?
