J S Machine
I've done this on a couple of knives, but I find it rather difficult due to the hardness of the steel. I'm trying to get some tricks together to do this, because it seems very appealing on finished knives in some cases.
The only way that I have done this is as follows. I don't have a belt grinder yet (like a cootes or KMG) so I don't have the luxury of putting a really fine belt finish on my blades. To hollow grind, I've been using something from harbor freight and it does a decent job but it leaves alot ot be desired It is an angle grinder with a right angle gear box and a gear reduced slow turning rock. The rock is about 1.5" wide and turns about 100 RPM give or take. It has a water catch up under it so you can run the wheel with water.
This thing does a decent job, but it is very very slow. It may take me 3-4 hours to do a hollow grind on both sides of a 4-5" blade. I usually do this before heat treat and leave a little stock, and then when it comes out I finish it. It leaves a decent finish on the grind, but nothing i would send out of the shop. I usually blast it after this and it seams to look alot better.
The question is, when you guys are hand rubbing these finishes - I'm assuming using progressively finer sandpaper, do you do everything after heat treat, or do you work it up to 1200-1500 before heat treat and finish after? The one that I did was extremely hard to do because of the hardness of the steel. Is this just part of the game or is there a way around it?
I'd like to do some hand rubbed finishes, but I want them to look presentable and I could use a few tips.
Thanks
Thanks
