Hello all, Looking for a bit of advice here from ya'll folks with LOTS of forge knowledge (Ed & others
Here is the forge with blower with stuff I had on hand for a quick 'n dirty setup for testing. This is the $78 blower from Amazon. The big pipe is 1-1/2" SS pipe with 2" PVC to connect bower to burner. The short section that goes into forge is 3/4" pipe. The end of 3/4" pipe is just flush with forge shell, not into insulation at all. The insulation has sort of a "bell" shape. This forge was originally built for a Venturi burner. I should mention there is no jet, only the 1/8" NPT nipple from gas hose to elbow at 90°.
The forge is running around 2 psig, with needle valve not full open. The blower is about half open, running on 120vac. At this point the forge has been running for perhaps 10 minutes max, and is settled in nicely around 2290F. If I close the blower inlet off fully and close needle valve a bit the forge will settle down around 1950F to 2000F range. My question is about the black spot in the forge. The black spot is where the flame hits from the burner. When I back the blower and gas flow off a bit to drop temp the black spot gets larger. Is this normal for a blown forge?
Oh, the video is mirrored from actual setup, not sure why it mirrored when I uploaded to youtube, but it did. I looked for a setting to flip back but didn't find one.
Thanks to all for any comments or suggestions
