First Sword Scabbard
LRB
My first attempt at a sword scabbard. A bit of a challenge, but after three trys on the leather, it all worked out. All steel fittings. The tip is three pieces silver brazed together. Two halves and a bottom plug. The throat is also three pieces. The main body with a brazed seam in back, and 650° silver soldered top plate. The frog hook was made from a bar of 3/8" steel, sawed and filed to shape, then pinned and brazed to the throat. The sword was made by Jared Secrest under the guidance of Kyle Willyard, light in weight, and wonderfully balanced.
Yes on the hardware. That is also my first tip/drag/chape, that was multi-pieced.
Wick, your work is amazing! :jawdrop: Your knives and your sheaths have such a distinctive style too then I think I could recognize then with out a name.
All I can say is "you are the man"! :35: I am proud to call you my adopted mentor, if my stuff ever gets too be half as good as what you make I will feel like I have got there!
