Travis Fry
I should preface this by saying that I've made exactly 2 damascus billets ever under the close supervision by folks who knew what they were doing, and neither needed to have the pattern flipped so that it would show up. In other words, while I've done enough reading to be familiar with various methods for exposing a mosaic pattern and know how to go about them IN THEORY, I'm curious for some pro feedback on the pros and cons of the various methods. Why would you use one or the other?
My take so far from what I've read:
Ferry flip: Probably the best way to prevent distortion and material waste, but requires some MIG/TIG welding equipment and skill. Also requires lots of flux or (preferably) dry welding with joints sealed by application of the aforementioned welding equipment. Rewelding the billet after flipping seems to be where a lot of folks fail, so maybe this is harder than it looks. Either way, this is what I tend to lean toward, given my vast knowledge and experience
Accordion: Maybe the easiest, since it avoids rewelding to reorient the pattern. Can distort patterns (though there may be ways to mitigate this?), and produces a lot of waste. Unless you make some "fossil" mosaic with the pieces. In any case, you end up with a smaller billet.
Loaf and slab: For sure eliminates distortion, but sawing off blade width pieces from a relatively large chunk of patterned steel seems like it'd take a heck of a lot of time. I think I'd probably use this for something like feather, where either of the above methods would probably eff up the pattern.
Am I missing anything? Can some folks who actually do these things chime in to further the discussion?
