I have a bottle of powder butseems to have all crystallised and stuck in the container. I guess some moisture got in there. Any tips on getting it out? It would be easy if I could just add water but I know this is not the thing to do with acids.
I'm going to push the envelope here (maybe) and suggest carefully adding water to the bottle until you have enough to dissolve all the crystals enough to pour them out of the bottle. It's my understanding that the whole 'always pour acid into water not the other way around' suggestion is merely to minimize the risk of splashing the acid around when you pour the water in too fast. If you pour slowly and carefully, there should be no problem. Make sure you take all the other appropriate safety steps, gloves, goggles, don't have your face directly over the bottle and don't breathe any fumes coming out, etc.Any tips on getting it out? It would be easy if I could just add water but I know this is not the thing to do with acids.
I'm going to push the envelope here (maybe) and suggest carefully adding waterto the bottle until you have enough to dissolve all the crystals enough to pour them out of the bottle. It's my understanding that the whole 'always pour acid into water not the other way around' suggestion is merely to minimize the risk of splashing the acid around when you pour the water in too fast. If you pour slowly and carefully, there should be no problem. Make sure you take all the other appropriate safety steps, gloves, goggles, don't have your face directly over the bottle and don't breathe any fumes coming out, etc.
