BrandantR
For the two years that I have been making folders, I have been putting my signature on the inside of the back spacers through chemical etching. It's really a pain to mask off the spacer with acid resist, scratch the signature through the resist, and etch the mark into the steel with acid. I have been able to get some fairly good results, but for every good etch I have two or three mediocre ones. So, in order to improve results, I'm entertaining the idea of using an electro etcher. I know that there are many out there that use electro etchers, so I want to pick your brains and get your opinions.
I have been looking at the differences between the Personalizer and the Personalizer Plus units. Apparently the major difference between the two is that the Personalizer Plus has variable output voltage. Is the variable voltage worth the significant difference in price?
I have also considered building my own since there are a few plans floating out there in cyberspace to do so. I have some electrical skills, so I'm not afraid to try. Has anyone here built their own and does it work as well as a commercially made unit? Any insights to consider when building one?
I'm also open to other options and units that may out there. I really want to get a good, consistent mark so I can start marking the blade instead of hiding it inside the back spacer. I appreciate any feedback and advise that you may be willing to share.
