Grizzly Bear
Hey Guys,
I have a question about the use of Danish Oil on burl wood scales. I sanded my handle down to 1,500 grit and polished with Tripoli Brown. I thought that I should seal it with Danish Oil. I followed the directions on the can of Danish Oil: thoroughly coat and hang wet for 30 min, coat and wait 15 minutes and then wipe dry. Don't polish for 24 hrs.
When I first put the coat of Oil on, the scales glimmered brightly. By the end when I wiped them dry they were duller than before I even started this process. Do I need to keep putting more coats on and let them dry between coats and not wipe it off or is this the way it is suppose to work and when I polish them they will shine up again?
Do you even need to put Danish Oil on stabilized wood?
One more thing. Does anyone use clear exterior lacquer to finish their knife handles? I am thinking that this would be very easy to do and if sprayed on the bronze guard and pommel, it would keep them from corroding. Is this a good idea?
Your input will be greatly appreciated.
Thanks,
Grizzly Bear
Thanks,
Grizzly Bear
