Shane Wink
I am working on another bushcraft/survival style knife with a 3/16ths x 1 1/2 x 5" long blade and want to convex it but I am not sure how to know whether to go 1/2" 3/4" or full height. Should I flat grind HT then place the convex on the blade?
The intended use for this blade is to help me on my trapline this year. I cut and split a lot of wood for snares during trapping season and the knife I was using needs replacing.Cutting trigger notches and batonning through wood , trimming limbs, cutting rope as well as helping process some of the game will be its main function.
The one I am replacing was a blade I made a couple years ago.Flat ground with a convex edge. Many times I would have issue with the flats getting stuck in some hardwoods and I was worried about breaking the tip off but it never did. Now that my grinding skills are growing and knowledge as well I intend to replace it
Can anyone help me understand how high and how to grind the correct convex cross section for a blade like this with the above dimensions?
