Challanges for Damascus and Ivory Knife
backtines
Hey Guys ,
I thought Id bring you in to a few of my challanges Im having building this knife .
I had a request to build A knife 12 " OL w/ 7 " blade Damascus with Ivory scales. He wants to get the ivory scrimshawed and was very specific on the design and look of this knife before I started.. Im so not used to that ..I just make knives that I like and people buy them . This deal , I was following a plan ..
Anyway , as some of you already know in order for me to pull this off , I had to get rid of my grinding jigs and grind the blade free hand . Ive only grinded a few blades prior to this one without jigs and thought I should practice more before I jumped into a 200 dollare piece of damascus .. I couldnt resist. I started grinding on this knife a few weeks ago and It came out ok .. I got plunges pretty good , not as straight as I like but ok .. My grinds came all the way up and my logo looked good for the time being. After HT , I was happy .. The blade was perfectly straight.. I ran my first temper cycle. No problem .
The following day is when it all started to change.. I was running an hour late from work, so i asked my wife to bring toaster up to 375 then put the blade in . I figured shes seen me do this 100 times there should be ne problem. WRONG !!!!!!!!!!!!!!!!!!
I got home and found the blade sitting on the very edge of the toaster cooling down with the door open. Long short , she never put the blade in the middle of the toaster where the heat would soak the blade evenly .. She put it right on the edge , because it was too hot for her hand to move the blade in deeper .. Needless to say , the blade looked like a pretzle..
Now the fun began trying to get this thing straight, I heated the spine into the ricaso . Tweaking it hear and there and redoing this and that .. Then I startedgoing over my grinds and trying to fix plunge lines ect.. I remember in school , for every action theres a reaction and thats what was happening .. Everything I did , Id mess something else up . I was going nuts! I then had to reflatten everything and by doing that, I had to go ever my logo .. Its still on but you can barley see it . I didnt want to heat that aread up and whack it with my stamp because I was afraid something would give , so I left it .
MAde my bolsters. They came out ok, bif for my taste but I guess they'll do .
The Ivory ..I glued some black liners to the back for two reasons. 1. to give me a little more height to work with . 2. during expanding and contracting , I believe that the liner would take some of that . Instead of a direct hit on the ivory . Hoping that it wouldnt crack.
I found out later that 3/32 reamers had a few different sizes . I drilled my 3/32 holes not realizing that i should have been a little under sized to acept my reamers. I could have done that better .. Should have got actual sizes of pin stock , drill bits and propper reamer for that part of job.
I had to built the whole knife with temp pins , grind to fit and finish because i wanted to spine to show its grain after etching.. I didnt want to grind that stuff away during final F&F.
So I built the whole knife .Grinded the ivory VERY CAREFULLY !! not to get it hot .. I used sharp drill bits and took my time . One of the black liners moved in the corner of bolster and scale . I had to redo that . ( I found that mistake after I was done of coarse )
Big challange was the bolsters.. I couldnt really get into shaping them nice because I couldnt peen in the pins. So I glued them in , got them real close and was hoping to finish them nice after etching ..
I etched blade , Looks beautiful ( Thanks Randy ) I start reassembeling it and of coarse nothing lined up as it did when I pulled it all apart .
After peaning the bolsters , there were high edges, and because the bolsters were a little off , the scales follewed a bit.
Heres one I didnt expect .. When I glued on the scales and pushed my pins through. I noticed that black came up through the pin holes and onto scales.. That was the blackstuff that forms on the steel when I pulled it out of FC. I never cleaned the pin holes out and it pushed the black into the ivory holes .. Now I have a black lined ivory pin hole !
SO I had to regrind all the high edges and had to wash out spine and belly of knife. After I was happy with not having high spots and took a fine paint brush and very carefully re etched the spine and belly.. I was able to bring the grain back ..
News to me.. After the ivory was polished and shined up real good . Thats when I etched . The FC DID NOT ! soak into the ivory .. I was able to let it soak on spine for a while , then spray it off with Windex .. That was a relief.
So Thats where I am for now . I need to do some more hand sanding on the ivory .. Need to get out some scratches that are showing up in different light .. I may bring the bolsters back down to a satin finish . I still have some faint lines in there and Im afraid to keep going over them because I dont want to get into trouble with halos in my bolsters.. I taper reamed them out but who knows .. I dont want to bring on another problem. We'll see.
So thats it for now. I guess Im happy .. I will definitey do some things differnt on the next one .. I should have it finished with in the week and Ill post pics..
Thanks for listening .
Mikey,
I feel for ya! If your going to be a knifemaker you have to learn how to fix knives,mostly the problems you bring on yourself.
These kind of projects are the ones that teach you things that you will never forget and never repeat.
What it all boils down to is,you gotta pay your dues,no matter what your trying to master.
Keep at it,you'll get it done,and the next one will be better.
Now you know why some knife makers will not make knifes to order. I also wouldn't have taken a commission for a knife that I didn't have experience with some of the materials being used.
Doug
Doug
I definitely see the challanges with making knives to order , but Im always up for the challange.. I guess taking on some of these challanges would only teach and help me in my knife making in the long run. For instance I probably would have never bought a 200 dollar piece of damascus and 200 dollars worth of pre ban ivory and made a knife on my own, but now after doing this project , I just might. I learned a lot doing this and I know what NOT ! to do next time. Thanks .
Both Kalvin and Doug said it all as I see it, however the three of us - myself and I figure the other two - are also pleased you were able to go for it and come up with a knife you are pleased you did !! Frank
Thanks Frank , Hope to finish up the sheath this weekend and Ill post a few pics.. Another thing that Im learning is to STOP !!! messing with the knife when its done ! I find myself continuously going back to the buffer and resanding these little blemishes I see in the bolster or handle .. I need to learn to stay away from the knife when its done.. But its never 100% done .. The more I mess with this , I end up making matters worse .. Espicially my bolster pins .. now they are very very slightly starting to show.. All that work . I had a great job done and now the darn pins are just starting to show ..
Learning from each knife I make is what keeps me going and makes me try harder on the next one. Your knives are always very nice Mike and I'm sure this one will be as well. Keep pushing yourself to try new things, you will be glad you did in the long run. Cant wait to see some pictures of the knife.
Here's a suggestion Mike,engraving will hide those bolster pins nicely,but it must be good engraving. Give it some thought.
Ya know Cal , I would love to have this knife engraved .. I actually suggested this to the customer when we were drawing it up . Its gonna have to be his decission .. After I give this knife to him , we will talk .. But Id love to have it done ..
Thanks You Cal
