cardoso5fr
A small balisong with bowie blade. 115w8, full hardening, and Ta6V4 handle. The blade is 3 mm thick, , 8.5 cm sharp, flat grind, 12.5cm closed, 21 cm long, hardened 100c6 tang pins.
1.2 cm thick to the screw.
Stainless steel bushing, but without the right shop that is a bit boring to make a perfect bushing to the right size. Tappered hole to 6mm, bushing to 5.95 for 3.3 mm high for the 3mm blade + BP washer.
Ta6V4 Tlatch on BP washer.
I hate to make latch......
