2" X 72" belt grinder for sale
acourtjester
New Member
DIY Belt grinder for sale,
I have build 7 of these grinders using Jeremy Schmidt's construction plans, with upgrades to design. This grinder has a 2 HP 3 PH motor with VFD for converting 220 Volt AC standard house voltage. The VFD has a remote control panel which can be located away from the grinder itself for on/off and speed controls.
Construction is 2” square tube, 2.5” square tube with 1/4” wall, and 3/8”plate. Most of the grinder is Powder coated for looks and easy cleaning. Aluminum wheels with sealed bearings one is used as a tracking wheel and is fully adjustable for aligning the belt while in use. This is commonly called a knife grinder, not being a knife makerI use it as a standard shop grinder for many projects. The platen can be removed for a slack belt type grinding to shape metal. It has a table for a flat surface to maneuver what is being ground, which can be adjusted to a 45 degree angle. The grinder can be rotated from a horizontal to a vertical (90 degree) to change the grinding direction relation to the table. Comes with 2 new belts for the grinder. Price is 1000. cash picked up at my location only.
Video on the Google drive showing the grinder, as stated the 8” wheel attachment does not come with the base unit.
https://drive.google.com/file/d/1x90Pc46NifX826aVOvmkcVYA6K8lgQ2w/view?usp=sharing
