Doug Humbarger
Since I pretty much suck at soldering/brazing I was looking for an easier way to make a habaki. This is what I came up with. A blade is more or less a flattened circle. Sooo measure the flats on the blade; in the case of my dagger there are four flats. Each flat is .625. .625x4= 2.5 which is C (the circumference)
2.5 divided by 3.14 (Pi)= .796 ( the inside diameter). I machined a copper ring on my lathe with an ID of .796 & a thickness of .050. flattened it out till it would start on the blade and kept tapping it farther up the blade with a corian block. Hammered it completely flat & sanded out the hammer marks. This is the results.
![Habaki.jpg Habaki.jpg](https://knifedogs.com/data/attachments/26/26426-fd1fd8586b20687cf4195fa8a22bc65b.jpg)
