CDHumiston
I usually use steel from Alpha Knife Supply and I've had no issues at all with warpage.
I heat treated three blades last night using steel from Aldo (NJSB) and all three have a slight warp.
I used the recommended times and temps from the site so I'm not sure if it's just the steel.
All three blades were AEB-L. Hardness came out to 61 HRC after two tempering cycles of two hours each.
