Michael Kemp
I've done 3 cycles of dish-brush scrubbing with dish soap, rinsing in hot water, and air-drying in the dish rack. This has had major effects on all blocks. The good news so far is that none of the blocks appear dried-out - all seem like they are still protected from total drying. None show any sign of cracking or checking.
Linseed Oil - only a ghost of the surface luster remains. The Oak block still has a small lustrous spot in the center of the top of the block - other than that the blocks have lost their glow.
Veg Oil - about the same as Linseed, but without the lustrous spot on the Oak.
Linseed/Spar/Turp - the Cherry looks as bare as the Linseed and Veg Oil blocks, but the Oak still has a hint of luster.
Salad Bowl Finish - the Oak block has retained a little more luster than the Linseed/Spar/Turp Oak block - a very light even glow. The Cherry block has a curious pattern of low-luster and no-luster - sort of splotchy.
Tru-Oil - Maybe my 9 coat process was not enough or not evenly rubbed down between coats: there is very little remaining luster on either block - and what /does/ remain is in dramatic splotches - as if those areas were applied more thickly or bonded better to the underlying wood.
Permalyn - both the Cherry and Oak blocks have kept a slight lustrous glow.
Epoxy (Penetrating Epoxy, CPES) only: looks just like the Veg Oil blocks except lighter in color.
Briwax on Epoxy base: only a trace of the wax on one end-grain side - otherwise identical to Epoxy alone.
Renaissance Wax on Epoxy base: no trace of the wax - identical to Epoxy alone.
Wipe-On Poly on Epoxy base: very similar to the Salad Bowl Finish (a slight glow remains) except that it is a little blotchy in where the luster shows on both the Oak and Cherry blocks.
CA Glue on Epoxy base: The Oak block looks almost untouched - there is some loss of coating on the end-grain sides. The Cherry block is more affected - the coating remains in blotches on all sides. Maybe I did not get the application or between-coat sanding quite even. Maybe it just adhered better in some places than others. I'm betting that a nice thick CA coating would have stood up completely. I just can't get on board with making the wood look and feel like plastic.
Next up: I'm going to buff all the pieces to see which bring back some shine. I'll report on that and then do a 15 minute soak in hot soapy water followed by air drying in the dish rack.
