Two general rules that come up time and time again in industrial heat treating discussions, are:
#1. The end use application of a part or component dictates it's heat treatment.
#2. Use the slowest possible quenching medium necessary to achieve the desired structures and/or properties.
well you missed em good buddy as far as industrial production goes.
1) heat treatment must be performed as quickly as possible using least expensive equipment available. said equipment must be capable of running 24-7 for a minimum of 180 days without maintenance. heat treat quality is not judged by hardness or other tests, but by number of returned parts we can't blame on our suppliers or customers.
2) quench media must be inexpensive, non-harzardous(if you can't pour it down the toilet, we can't use it), non-staining, leave no residue, and have a low enough evaporation rate that the tank only has to be filled every 180 days
3) in our advertising, there will be no mention hardness numbers or chirpy tests or ....... use instead: adequate, functional, easy to maintain, meets all standards, and any other adjectives that are soft, fuzzy, and impossible to disprove in a court of law.
just observations of what i have seen in 40 years of maintaining equipment for the military and manufacturing firms.
scott
