cardoso5fr
The Finger Slasher Song i did for the Jerzeedevil Halloween Build Off
133 g (0,293pound)
16,1 cm closed (6,34")
27,3 cm open (10,75")
14 cm blade (5,51") sharp : 10 cm (3,93) real double edge
10mm thick (0,39")
Blade thickness 4 mm (0,15") 100c6 with differential hardening
Ta6V4 handle.
The 4 screw to the heel will be change for something flatter as soon as i will receive it:demented:
It's not perfect, the point is not perfectly centred between the handle in closed position, everything is not perfectly in line when it's open. One side of the grind is not perfectly symmetrical. But i'm happy to have complete that one
I hope you enjoyed the trip in my workwhop
133 g (0,293pound)
10mm thick (0,39")
Ta6V4 handle.
