jonathan creason
My plan is to knock out a bunch of these in order to spend more time focusing on forging and grinding. Nothing special, just 1084 steel, 9.5" OAL with a 4.25" blade, which I hot blued for corrosion resistance. The tang has a coat of truck bedliner under the cord wrap.
After fighting with it for a long time (because I'm stupid) the flat grind is finally starting to click. You can't tell it from this one, but a couple of others I have on the bench show big improvements.
Any criticisms are appreciated as always.
