Seax
I'm not sure what you mean with your question. Not sure what you mean by "a regular seax". The word just means knife so it covers a lot of territory. Broken back seax refers to a blade with a distal and proximal taper to the spine both in width and thickness from the peak of the spine with the resulting clip being about a quarter to a third of the length of the blade.
Doug
Doug
Hey Doug when putting a distal taper on a knife do you put it on the blade before you start grinding bevels or is it actually apart of the bevel grinding process. Thanks
Doug
This helps thanks
