cardoso5fr
The WIP is on the JD
The JD Flip them off, is a build off only about balisong set up by the balisong alliance by Ron labella on the Jerzeedevil forum. As i participated to all the build off since 2007 on the JD and two time with a balisong. I had to play on that one too
The Scimitar Bamboo Balisong
220G
110WCRV5 blade, oil hardening, 200°c tempering. Flat Grind
Stainless steel handle , bamboo style.
14,5 cm closed
Width 23mm.
10mm thick and 15 mm to the pivot.
Zen pins and ball bearing (the ball are in 100C6)
24,8 cm long (open) ,
Blade 11,5 cm (thickness 3,4mm)
9,8 cm sharp.
And a small video i did just after the sharpening. the temperature in the workshop is 2°c and outside, i have -2°c .
That is a really poor flipping session, but it just to show the result
http://dremeltingpotes.free.fr/Photos/Balisongs/BalisongBuildOFF2011/MOV09957.MPG
220G
14,5 cm closed
Width 23mm.
9,8 cm sharp.
