cardoso5fr
High tech Cardo No Kami
O1 tool steel, 3,4mm ,oil differential hardening, flash tempering. 10,6 cm long 15,7 cm long open
Highness 2 cm. Thickness 6,5mm and 10mm to the pivot. Sharp 6.7 cm
After the pict, tuan had the idea to fold the tail. i heat and folded the tail (without heat the other part of the knife . the result is not bad at all
