I decided to buy the NWGS plans two days ago. It's just a matter of time now
. Do you know where I can get tips on building it just in case I get confused. I think my drill press should be useful here. I have no idea what tapping is though...
-Pedro
Good call!
The plans are very detailed, and should easily provide all the information you need.
Simply read them over a few times if there is something you don't immediately understand. If you still have trouble, simply state what step of the process is giving you trouble, and there are lots of folks here who can help.
BTW, tapping is the process of creating an internal thread. (Think of a nut which threads onto a bolt.)
First you drill a properly-sized hole, then you use a cutting tool called a
tap to cut the threads.
A holder called a
tap wrench allows you to rotate the tap.
The best method is to chuck the tap in your drill press- this will ensure that you start off straight. Don't turn the press on; just lower the tap and turn the chuck by hand to start.
Once you have it started straight, remove the tap from the drill chuck, place the tap in the wrench, and continue.
Use plenty of cutting fluid, and work a little at a time. Rotate the tap a little, then back it up to clear chips (clogging with chips can break the tap). Keep going until you're all the way through.
The tapping process seems daunting to someone who has never done it, but it's actually quite easy.
The main frustration people experience is broken taps. Just do your best to start it straight, use plenty of cutting fluid, and free the metal chips as you're advancing the hole.
