This is kinda like a first knife pic except it's CNC instead of a knife. Pretty ugly but I'm proud of it.
Upper left corner show where I buried the spot drill and then plowed over to the next hole. Exciting stuff.
I worked on finishing the plate anyway. It's great practice.
The first tapping pass I had to do again as the threads weren't deep enough. I changed that and re-tapped. The machine clocks the threads so it didn't double thread. After that I found the tap was moving in the collet and getting shorter. Try a new tighter collet and I got the same results. The tap moved around a got shorter. I'll have to do some research on this. The collet was more than tight enough so I'll have to see what else I can do to ensure the tap doesn't move around.
In the mean time, this plate should work good enough to hold in the vise and make some one off parts.
