After heat treat quench knife has a black cooked like carbon, then it needs to be cleaned using a med. scotch belt to remove. Would it be easier to remove all by quenching it in muriatic acid, then take out and rinse with water so, acid won't eat the metal? Just, needing to know if anyone has done this to positive results instead of grinding the blade to clean it up before tempering?
