Has anyone used the micron belts supplied by micro surface?
I used to use their sanding pads in my pen making, and I'm sure these would make it much easier to polish since their Aluminum oxide belts go up to 12,000 grit which is sub 3 microns.
A 2x72 belt is $11 and change, so pricey, but if they finish the steel anything like they finished pens, then it would be worth it to save on hand sanding time.
I know that some use them to polish camshaft journals, but not sure how well they would translate over to knives.
http://micro-surface.com/index.php?main_page=product_info&cPath=273_197&products_id=91
