Craig, how much did it unravel??? I know when I am roughing mine out, like with a 60 or 80 grit belt, it gets pretty fuzzy looking and I can often pull some fibers out, but once I go to 120 or 220 grit, it's solid. The fuzzies are normal at coarser grits.
I went through 50 pumps (8cc for the resin, 4cc for the Hardener) of epoxy resin/hardener for the 6x11" mold piece, yikes!! A lot squeezed out, and the thick bottom pieces took a lot of epoxy for each layer. It's hard mixing the correct amount that you will need. I did 30 pumps, and then two more batches of 10 pumps each when I saw I would be needing more. Looks like around 20 oz was used. So $170 for 1.5 gallons of mix total (2:1 ratio), 20oz per 6x11 block, I can get 10 6x11 blocks 3/8"-1/2" thick for $170 in epoxy, or $17 per block, plus fabric cost. It's definitely cheaper to buy the store stuff, but for custom colors, it's worth it. $32 cost with fabric and epoxy, but I should be able to get 4 knife handles out of the block easily.
