When doing flat grinding you can pretty much go as high as you want with the bevel.
I dont measure angles, just scribe center line, break the esge with old belt at bout 45 degree angle, sometimes i increase it since i still eont have a very good handle on this then i mark a line tht will be the height of the bevel and grind till i reach it
Keep in mind this process is generally done before and after heat treatment (depending on steel and the heat treatment skill you can grind to your end measurement or leave a lot of room for error)
What might help you is creat several lines along the sides of the knife (different bevel heights) they will help guide you
