Lebanon
willows
hello to all guys,
This time I have tried in a friction folder a bit atypical, I hope you like it ;)
Thank you for your attention :)
- N690Co stainless steel blade (60 hrc), satin horizontally.
- Grips in African buffalo with texture.
- Grips milled internally embedded with a reinforced brass to make the pivot pin and the stop-over solids.
- Pivot (made ​​by me on a lathe) with anti-rotation system.
- Stainless steel screws.
- Stop Pins hardened steel.
- Length when open 6.7 in - 17 cm
- blade length (cutting edge) 2.36 in - 6 cm
- closed length 4.73 in - 12 cm
- blade thickness 3 mm
- weight 2.47 OZ - 70 g
Best wishes :)
