dswait
Another one I made from a file. This one was a test to see how quickly I could make a blade from start to finish. Took me 1 hour and 15 minutes to forge, grind, heat treat with torch, clean, temper with torch, clean, stamp mark, and sharpen. Then later the same day attached handle made out of bocote with brass pins and a few coats of tung oil that took only a couple of hours including for the glue to dry. The sheath actually took me longer to make than the knife. Gave away as a birthday present the next day.
