That's what I need, simple to make, OK? I drilled the wrong size hole right off the bat, too large of course, then tried to tap with a tapmatic and stripped it.
The vertical piece will get a cap that clamps the recasso with the handle facing away. Then a little adjustable support stand to hold up the end of the handle.
looking good mark,everything looks really nice. Just remember dont overheat the pins, easy to melt the kerinite,but shapes really easy with hand tools. great wip cant wait to see it done.
Worked on the blade, trying to get to 400g before heat treat. Drilled for guard pin and did a little profiling, rough cut the Kirinite.
The nib on the spine wasn't well thought out so slow going on the shaping, same with the guard.
Things go much faster when I have a definite plan and sketch, design as you go is slow, but sometimes I just can't visualize what I want.
I find a fine SS brush works very much better than a file card, also use it to clean my belts and discs.
Worked on the guard today, lots of file work, but the brass is very soft and easy. This will be soldered , my first try at it. Not looking forward to the clean up.
I've soldered plumbing pipe, and hard silver, but never tried a guard.
Haven't been able to get in the shop as much as I'd like the last couple of days. Scratch chasing mostly and refining lines. These curves are killing me but I'm learning a lot. I tried checkering the spine with a 30 line per inch file, this is my second attempt, hopefully I can clean this up a bit.
I keep getting called away, but managed a couple hours. Cleaned up the checkering and hit it with some fine paper before the pic and a scratch I had worked hard on reappeared.
The ovens are wax burn out kilns for lost wax casting The bigger one was $25.00 at a garage sale and the smaller one I just got in a lost wax casting package again from a garage sale. Need to get some bronze casting grain to try some guards.
Speaking of garage sales (we go every week end) found some file handles.
Waiting for the oven to reach temp. will post latter today.
Completed the heat treat and while it was in the oven took the head off of the lathe and checked what I could, found out the jaws had to be reversed, not sure why one side is true and the other isn't.
Got a 1' square sample of a counter top material good for chem. labs, very similar to paper micata, decided to use it. Turned the big pin and set up for the next one.
Need to clean up the blade then solder the guard, then the fun part, the handle. You really start to see what it's going to look like when the handle shaping starts.
Solder time, oh boy.The Stay clean- Stay Bright solder and flux can't be found locally so I tried substitutes.
Sanded w/600g, alcohol wiped fluxed and painted a perimeter with yellow ochra to keep it in check. No flow using a heat gun. Tried the paste flux also to the left.
I pushed the solder around with a little titanium probe and noticed it did flow right under the bead of flux.
Tomorrow's another day, hopefully with more success, maybe a torch in the works and some Stay bright on order.
