That's sweet! Is that a quench line on the blade? If so, how'd you heat treat it? Pretty awesome!
I know you didn't ask, but if it were me, I'd like to see a little higher degree of finish on that wood. Although I've never worked with it, I've seen others that really popped. Thanks for sharing!
The blade is diferentially heat treated. I used a torch.
The wood is not stabilized so I took it to 400 grit and then used 0000 steel wool. I finished it with Watco Danish Oil. If anyone has some suggestions about finishing the wood and making it "POP" I am all ears.
