C Craft
Well, it's a very simple affair, but I did take a pic this morning for you.
As you can see it's just a simple toaster oven (I think the wife paid $5 for it at Good Will) with a firebrick laying inside. I'd think any brick to add mass would work just fine. The PID controller is an Auber, looking at rear panel of oven you can see the TC probe mounted. As I said, it holds a more steady temperature at 400ºF than does the everheat I've got. The TC probe tip being located right at the blade is one thing that helps the blade hold a much more accurate temperature, while in the Everheat the TC probe tip is well above the blade.
Why don't you ride over some day and take a look at it, watch it work and hold it's temperature and how long it takes to stabilize - you're not that far away. Calvin also has a toaster oven he rigged up like this for tempering blades. for tempering SS backsprings I use the Everheat since over 1,000ºF is required for backsprings.
Ken H>
Ken I had to laugh when I clicked the thumbnail for the larger view, and see the plastic tub you converted to run the thing. But hey whatever works is what I say. I have been to every yard sale over the weekend and have yet to find a toaster oven. I did pick up a B&D workmate to use as a table for $10.00 bucks. I an not sure it has ever been used and he had it for $20.00 as cold as it was there wasn't a lot of people out and about so I figured he'd sell for $10.00 and he did!
Thanks for the pic I have some of this very same fire brick I cut slots in to do multiple knives at a time. I may have to take you up on the drop by one weekend!
