Doug Lester
After this perculated through the gray matter a bit I realized that Josh did have a good point even if it was for the wrong reason. If the bar of steel is heat treated before grinding it might very well not harden, except at the corners. If the bar is over twice the thickness of the depth of hardening then the bar will cool too slowly throughout to form martensite. It will form pearlite and the hard corners will be ground away on the edge. Hardening before grinding requires a deep hardening steel.
One thing that might get past this problem of heat differential during the quench would be to marquench. Heat the oil to about 440-450 degrees, just above the Ms point, and quench the blade for a few seconds to bring the outside and inside of the bar down to the same temperature and then allow the blade to cool in air. This will give the blade about a minute and a half to go below the Mf point. This should allow the thinner parts of the blade to form martensite and, hopefully, to prevent some of the temperature shock as the blade passes through the Ms-Mf range.
Doug
Doug
