Personally, I use the brass rod test on EVERY blade that goes out the door. It's not an indicator of any specific/exact hardness, but rather a test of the correct working hardness for the given steel, with the given edge geometry you've installed.
Don't fall into the mindset of "harder is better"! It's not! What you should shoot for is the correct hardness for the steel you're using, with the geometry you've ground on it.
Personally, I feel way too many knifemakers who only seek high hardness, forget that their clients/customer will eventually have to re-sharpen any blade that is used.... and if a client/customer struggles to, or flat out can't sharpen it because the hardness level is too high......it give the person who made the knife a "black eye".
I was caught up in the "high hardness" thing for a while during my early days, Rc testing nearly everything. After a while it became so predictable that I sold off the Rockwell tester...... it was just sitting in the shop gather dust and rotting.
What hardness level do I use? For the steels I use, and the geometry I apply, 57-59 is what I choose. I don't demand those exact numbers on everything....various designs/uses dictate.
